Recovery safety
Recovery safety
I read once that you shouldn't attach a tow strap to a ball hitch because the could break pff and kill someone. Where is the correct places to attach straps?
Are tow hooks any better? What is the correct way to use a towstrap?
JK-Forum Founder
This is correct. You should strap up to tow hook or a hitch with a D-ring mount whenever possible. Also, you need to make sure to get a tow tow strap that DOES NOT have metal hooks on the ends and to make sure that it has a 10,000 lb. capacity or more. If you need to connect more than one strap or need a way to hook up the strap to a tow point other than a hook, be sure to use a 3/4" D-ring for this task.
For more recovery info, check out the article I wrote earlier in the year:
http://project-jk.com/jeep-jk-access...ear-essentials
Try a Google or Yahoo search for "Recovery Techniques" and between reading and videos you will find enough to keep you busy for hours.
I wondered about this... if someone has slid off the side of the road, a normal car for example... what is the best way to try and pull them out? I wouldn't think there'd be a d-ring mounting point so would you use the tree strap around their frame and hook on to it? What if I only have the recovery strap without hooks... would I loop that around the frame of their vehicle?
I want to be able to help people this winter but don't want to do more harm than good, you know?
I've hooked up a chain that wraps around and hooks back unto itself with it attached to a d-ring that is attached to my tow rope. There's a lesser load with a small vehicle and even if it breaks it's under the vehicle so it should be contained.
I cannot say this is the best method, but it worked for me in the past on several occasions in Minnesota.
Last edited by tgrt; 11-26-2007 at 02:16 PM. Reason: deleted ASCII diagram, because the site wouldn't display the spaces properly
could always get you one of these. tow truck drivers use these in their recovery efforts, you can hook the hook in various ploaces. They alos make different style hooks and I think they make hooks that fit into frame holes, just depends how much you want to carry
just keep in mind it does have metal on the end and thus requires some serious thinking on hook up points for safety reasons. I don't like metal on the end of things, but you have to realize winches have a metal hook and tow truck drivers use metal recovery equipment, but they are trained to do it safely (at least some of them are).
