JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Rescue straps all knotted
Old 04-08-2018, 02:33 PM
Cutman's Avatar
Default Rescue straps all knotted
I just used my rescue straps to pull down a tree. And now they are mated together forever? I've looked up a few responses to this problem, and it seems a bunch of folks toss them after they get a knot in them. Is it really that unsafe to reuse them? And if so, how do you unknot them? Thanks!
Old 04-09-2018, 05:41 AM
eng23ine's Avatar
The knot does reduce strength somewhat, but i wouldn't throw them away if they were mine.
Next time you're joining 2 straps together put a rolled up magazine in the knot to make it MUCH easier to undo it. (NEVER use bow shackles to join straps)
Old 04-09-2018, 11:39 AM
Cutman's Avatar
I did read someone suggested tapping around the knot with a rubber mallet until it loosens. And it worked. And they were not technically knots. It was where I joined 2 together. Thanks!
Old 04-09-2018, 01:02 PM
63expert's Avatar
You’ve got an axe knot. Guess why they call it an axe knot!!
Try the mallet trick, I’ve used it many times on rope.
Old 04-17-2018, 10:15 AM
akguy09's Avatar
Why not?? if the shackle has the proper WLL limit I seen know reason they can't be used, unless crane operators and tow trucks are doing it wrong.
Old 04-18-2018, 04:19 AM
eng23ine's Avatar
Because crane operators and tow trucks don't "snatch" on their straps. The strap will break long before the bow shackle does and then you have a missile coming back at you.
Old 04-18-2018, 04:48 AM
jedg's Avatar
Use a soft shackle.
eng23ine (04-24-2018)
Old 04-18-2018, 05:13 AM
resharp001's Avatar
Received 1,815 Likes on 1,585 Posts
I'd say this is the same as using synthetic line on a winch. If strap breaks it's gonna fall the ground, unlike a steel winch cable with tension on it that would come flying back at you if it snapped. That shackle isn't going to come flying back like a missile. Am I wrong?
Old 04-18-2018, 05:15 AM
akguy09's Avatar
So then we can all take the shackles off the bumpers, because we aren't going to attach to those if we are "snatching" the vehicle. I do agree that soft shackles are a better option.
Old 04-18-2018, 05:16 AM
jedg's Avatar
Perhaps... but I still wouldn't do it. I know a snatch strap stores energy (it's got a built in stretch capability)... Once I found soft shackles, I switched to them...
Quick Reply: Rescue straps all knotted
