Rotopax bracket mounting question
Presume you are suggesting the rotopax would hang on the inside. How would you secure the bracket in place, by using the same bolt that holds the hard top down? The website shows that bracket to be just under 3/16" right (.172")? I'd think that would be a little thick to try to sandwich in there without your hard top sitting a little wonky.
I actually was hoping to mount it with the bracket outside and pointing up, just forward of the fuel port. Yet as I look at it, it appears that would require some modification to the top which I'm not willing to do. And yes, I agree the thickness would present a challenge too. For now, I will keep the Rotopax mount on my roof rack. Thanks!
I like the front fender mounts from retrofitoffroad.com.
Im going to put a Rotopax mount on my rear rack, not to carry a can just to place to siphon gas into the tank.
