Winch/synthetic line
Hey everyone,
I am about to purchase a warn 9.5 ti winch. It comes with 5/16 winch line. I want to buy Viking synthetic for it. Do I have to buy 5/16 or can I buy the stronger 3/8 synthetic line for it?
Thanks so much,
Sean
Thanks so much,
Sean
You have a 2-door so you are fine to run the smaller diameter line. I ran it for 4 years on my TJ. I did change over to the larger diameter line when I upgraded my winch on that jeep and also run it on my current JKU.
Originally Posted by grim_creation
It'll fit, you just won't be able to spool as much line as you would with the thinner line.
Sent from my DROIDX using Tapatalk
Remember that the less raps on the drum equal more pulling power. If you go with 3/8 line and 100 ft you can always get an extension if you need a longer line. That's what I did. I went from 100' of 5/16" cable to 85' of 3/8" line. Then I will just get an extension in case I need more line.
