Originally Posted by ECHO
(Post 2300532)
Ohh okay.. you have an XRC-8.. I have the 10.. Haven't had mine stick before.. Maybe someone who has, may jump and offer some advice.. Sorry
Have you tried jocking the lever while using the remote having the cable go in & out? XRC 8 also |
Just my 2 pesos here. I had that hapen to my Warn M6000 on my YJ, I found out if you take the switch off with a philips head screw driver (or what ever is holding it there) and pop it off and use a bigger flathead screwdriver where the switch is and shift it.(all your switch is i do believe is a came lever) Then it would be a good idea like the others said to spray some of your favorite lubricant in there and then put it all back together. There is nothing in a winch thats too complicated.
Just yesterday , I was in front of my jeep and thought about this thread. The lever was stuck again. I pull the cable an inch or two, and it released. I sprayed wd40 on the lever and checked today its still free to slide.
Originally Posted by Enzo
(Post 2312293)
Just yesterday , u was in front of my jeep and thought about this thread. The lever was stuck again. I pull the cable an inch or two, and it released. Too sprayed wd40 on the lever and checked today its still free to slide.
Originally Posted by 08JKRHD
(Post 2312304)
Maybe I lost my mojo when I sold you my cover...:rotflmao2: I've tried moving it every which way to no avail. I'm going to try taking off the lever and spraying it.
(Post 2312304)
PS I put my kc's long range slimline lights on the fair lead, without bracket extensions. Thanks for the idea. Now I want a smallerlight for the kc's window bracket. |
(Post 2312343)
You want the cover back? LOL...........
6 Attachment(s)
Hold on, y'all got lights on the fairlead? I wanna see!
(Post 2312662)
So they're bolted up to a piece of steel/ aluminum that has a 90* bend in it? That is really cool and beyond genius. I'm guessing they put out a nice light pattern and there's no glare.
My XRC8 is doing the same thing today, but it is stuck in freespool. Pulled all the line out and took the synthetic line off to change the hook to a safety thimble. Reattached the line and went to engage the clutch and...........Nothing:mad:. I tried everything you guys mentioned in this thread, but couldn't get it to budge. I'm going to let the PB Blaster soak in good overnight and check it in the morning. This thing has only been on the Jeep for 2 months. I haven't even gotten the chance to use it yet. Good thing I got the extreme lifetime warranty from 4wd.com. I guess Bustabizz will be getting a call tomorrow.
