JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by CARiD
Click Here
Winch won't freespool? Please Help...
Old 04-12-2012, 12:48 AM
  #31
Tycho's Avatar
Tigerz11 have a new clutch lever that they call 100%engagement. Different setup from sliding ring gear. Lever goes all away around with every 90 degree notch alternating between engaged and free spool. No need to worry about teeth not lining up etc.
Tycho is offline
Old 04-13-2012, 04:44 PM
  #32
AlphaRomeo15's Avatar
i used my gun cleaner spray (winchester powder blast), gave it a couple of minutes and i was able to free it with no force. Nice to know my hobbies can cross paths lol. I guess checking the lever often would be a best practice.
AlphaRomeo15 is offline
Old 05-10-2012, 04:04 AM
  #33
killbilly's Avatar
ugh... just found out last night that my XRC8 won't freespool either. i have managed to at least get it to wiggle after some penetrating oil and some tapping on the case around the lever but still wont engage the freespool. hopefully over the next day or so it will free-up because if i have to take it apart to fix it, i will have to take my whole bumper off to do it...and i dont wanna do that...lol
im kinda wishing i spent the cpl bux on a cover for it now...lol.
not really the first post i wanted to make on here
killbilly is offline
Old 05-10-2012, 04:12 AM
  #34
How much was the extreme warranty? I just bought my xrc10 from Bryan about 3 weeks ago now, maybe I can buy it and add it on since I haven't even made a pull on it yet.
$25 bucks each!
Bought 2 of them (XRC8s though) on different dates and different shops. One from 4wheelparts/4wd online and another at an actual 4wheelparts store.
sclan is offline
Old 12-05-2018, 10:59 AM
  #35
SporticonJKU's Avatar
Sorry to revive a long dead thread but I'm having the opposite problem, I cannot get my winch to spool "out" under power with the remote. I was wondering if any one has had a similar issue? I bought a the XRC Gen 2 9,500 on Black Friday and installed it with no issues. Everything worked great when I did a quick test with the in/out on the remote to check if I wired everything correctly. The next day I went to practice using the winch and had no issues with free spool and spooling in but when I hit spool out on the remote nothing happened (not even a click from the solenoid).
I've been in contact with Smittybilt and tried the winch motor and battery troubleshooting test as directed and the results led us to believe it was a solenoid issue. They sent me out a new solenoid and after installing it there has been no resolution to my problem. I'm thinking it's a remote issue, any one have any other ideas? Does anyone know a way I can test the remote without using another winch or remote (I don't have any friends with this winch)?
SporticonJKU is offline
Old 12-07-2018, 10:35 PM
  #36
Mark Doiron's Avatar
Originally Posted by El Jefe View Post
... There is nothing in a winch thats too complicated.
Have you ever opened up the planetary gear housing? :-) That's what I had to do on my Warn PowerPlant when the lever on it stopped moving. And there is grease inside of that housing. For those spraying it down with penetrating lubes, I'd recommend you not do that. That will destroy the grease in the gear housing. If anyone is going to open up that housing, take pictures as you do it. It is complicated with I swear at least a couple dozen gears in there that can easily fall out of place. The pictures will let you put it back together correctly. Once open, use liberal amounts of marine axle grease. I did mine about eight years ago and haven't had a problem since.
Mark Doiron is offline
Quick Reply: Winch won't freespool? Please Help...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
