4 drs rescue green Rubicon on 35" /15" wheel
Wow, that looks good! Is that really the 2" full traction lift? I called FT last week about running anything bigger than a 33" tire with their 2" lift and they told me it would rub pretty bad if I did any serious wheeling.
wheel was Walker Evans 4.5 BS
yes they rub in the front, on the plastic shield under the bumper and will hit the top fender on flex. But it's a daily driver, she already had a jeep for trail.
We will modified the FT kit, the spacer in the back, dont keep the original rubber spacer , so the coil moved from where they suppose to sit.
It running on the road like the original 32", and the 35" was not balanced, i dont know if there enough room to stick some weight on the wheel to balanced it.
