AeroForce Interceptor Gauge
Got my AeroForce gauge installed. Took me longer to mount the gauge pod than it did installing the gauge. Its a simple plug and play gauge. Plug into the OBD and your off. I need a masters degree to figure this thing out. It shows so many things, most everything your computer spits out. It does come with an optional white faceplate and silver trim ring. I liked the all black. Going to have a custom A pillar mount made but had this pod and it will serve its purpose for now.
Check out the specs here - h t t p://www.aeroforcetech.com/products_interceptor.html This gauge can even do some of the things my Superchips tuner can do, and some that it cant... Low and high fan control Transmission reset ESP disable/enable Tire size diameter Idle speed TPMS threshold Rubicon model - Sway bar removal dash light disable Axle Ratio Read and clear trouble codes 0-60 time 1/8 & 1/4 mile speed https://i892.photobucket.com/albums/...e/SANY0315.jpg https://i892.photobucket.com/albums/...e/SANY0316.jpg http://i892.photobucket.com/albums/a...e/SANY0318.jpg |
Is that black tube part of the guage deal or is it a grab bar? I have never seen that:dontknow2:
2 Attachment(s)
Looks good. Another option is mount it on the center console like this.:thumbsup:
1 Attachment(s)
Here's my solution, got the mount on e-Bay from some guy in Australia.
Originally Posted by Strutssound
(Post 1851015)
I like it! This is on my short list of things to buy. I have noticed that some of the gauges are illuminated green, others are blue. Is this an option that can be changed with a setting in the gauge, or just different gauge models?
Anthony |
Originally Posted by Davebone42
(Post 1850551)
https://www.jk-forum.com/forums/show...97#post1660197 |
Originally Posted by sixty5vdub
(Post 1851090)
Anthony |
Originally Posted by EarlyJk
(Post 1850954)
Cool gauge by the way. |
will this give you a transmission temp?
| All times are GMT -8. The time now is 11:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
