Aftermarket driveshaft
Who's running after market front or rear drive shafts or both? What are the pros and cons to what your running.
Pro is no boot to tear and sling grease. Smaller diameter for better evap clearance. Also gives additional range if adjustment for you castor.
sent from my work leash |
Tom woods for the extra strength
I run Adams Driveshafts front and rear. I have banged them both off the rocks without issue. I highly recommend them :thumbsup:
Ease of owner maintenance with fittings that can be greased.
Noob here, so I see on aftermarket driveshafts ther re yoke ends and non? huh? can someone explain the benefit of a yoke over factory style?
Originally Posted by genrec
(Post 3998405)
Adams 1350 Rock Crawler Driveshaft. You cannot go wrong.
