Maertz's Half Ass Build Thread
#481
It really didn't take long. Getting the fuel lines out from behind the bod and moving the fill spot when i still had the stock tank took a bit. I ended disconnecting a lot of the lines to get them out. Removing a couple body mounts to raise the tub would have probably been alot easier.
#482
Ringer or dirtman what gauge sheetmetal did you use to fill in the tub where you cut it? I literally have never done any sheetmetal work and alot of the local guys here that do on there cars say it can be a pain.. Ill have to start looking into this soon.
#486
My neighbor has this in his backyard and i can use it whenever.
Manual Tube Bender RDB-050 | Baileigh Industrial
Its actually a pretty nice set up, he has the bend-tech software to and that bender is in the sotware so you can calibrate it and it tells you exactly how to do everything, its a pretty bad ass set up. I think his only regret is not going hydraulic. Also the degree measurement is kind of cheap, but its dead on once set.
#488
Sent from my LG-LS980 using JK-Forum
#490
The key with any bender is the cost and availability of the dies. I ended up with a JD2 model 32 and the Swag hydro kit. Dirtman has a M32 as well. Be prepared to drop coin on the dies. If you watch Pirate you can find some used ones.
