Maertz's Half Ass Build Thread
#526
Tons of dash lights.. People said i can run no evap as the evap doesn't cycle when it shows no gas. I have a cel for that. Also one for the fuel level sensor. Carolina truggies claims they dont have either light and have the same set up. Also cut out the parking brake and have that light. Not sure how that one works. Abs esp and bas and such im assuming are from my sensors not all being hooked up on the wheel speed sensors. Not sure if its possible to get the gas light off either. It doesnt appear the sending units are the same range so using the stock gauge will not work. Abendx you got all these lights on?
#527
Hmm
On mine....
* No evap. no codes thrown.
* Fuel sender gave me fits. I utilized the stock sender/pump in the GR tank, which required mild modification. After a second complete tear down and rewire of the sender/pump, it worked fine. So I must have crossed a wire or missed a connection the first time? Then levels were way off and it took a few reseats to get that working fairly well, yet I still can't get it perfect? It doesn't look like you are using the stock sending unit and I am, so I am not sure if that has anything to do with why I didn't have codes once my wiring was right?
* Parking brake is easy.... get out that hanging wire and complete the circuit to ground.
* I pulled everything related to safety systems, so I can't help you. One day I plan on taking the dash out and neutralizing those lamps. I can make a write up for you if it would help?
* Gas light... as in low fuel? Mine is only on when I have low fuel.... but I am pretty sure you figured out why.
#528
Ha a write up would be great but only if it has all steps no skipping... Well at least ill fix the parking brake and that light is red so it wont look as angry after...
On a side note anyone have experience with external pumps? This ones loud as shit in the cab... No biggie just curious if its normal.
Side note ordered rims 17x9 with 3.5 bs... Also got 4 39.5 irocks about 5o percent tread to get me by. Hopefully installing thus weekend... And doing gears sii i can drive this pile.
#529
Mine sits about 30 inches behind me, in the tank, and I can easily hear the pump.
And... you'll have to check once you have them, but I'm guessing you'll need a spacer on those hubs. I run 1.5 and rub still.
