Mojave Road Flex
There's no rubbing on the fenders anymore after the 1" bodylift. However in the picture above the front passenger tire is actually rubbing against the LoD bumper a little. It only does it if the wheels are turned the way they are. It was even worse with the factory bumper. If I had a stubby bumper it probably would not rub at all.
Looking a the pictures in you galley it looks like you started out with the old yellow OME shocks and upgraded to the long travel shocks. Did you only swap out the shocks or did you add extended bump stops at the same time?
Just curious as I am close to pulling the trigger on the Northridge OME LT kit but want to run 35s. If you’re rubbing with 34s I am not so sure this Northridge kit will work with 35s. However, if you are running without extended bump stops that would absolutely explain the rubbing on the fenders before you added the body lift.
Thanks!
Thanks!
Thanks!
Thanks!
