my play on the diy cargo cover
my play on the diy cargo cover, fixed most of the pics
just finished my cargo cover. wanted to show it off a little
sorry about the upside down pics, I cant seem to fix them. they are upright in my computer, just not after uploading them here. any pointers on how to fix it and I will gladly do so
The following 2 users liked this post by mrsmith210:
Infidel_Porkchop (Yesterday),
Whitlbc (04-30-2022)
I got a little vertigo from some of the pics being upside down, but it looks good!
Very nicely done. I like it a lot and will probably steal this idea. couple questions...Is the material 3/4" ply? ...how did you seal off the back side behind the seats? what are the vertical pieces you have underneath?...just supports?
Also, when i pop open the pics, they are upside down...if i click on them again it opens them up and they are flipped back correct. No clue why
Nice job!!! The 7 slots are a nice touch. Confused on what the wiring photos and the photo of the 2 buttons relate to or how they fit in to this project? Will be nice to know for when I hijack this project for myself!
I think he was just adding in pictures of a couple other projects as well....adding seat heaters and what I presume are garage door opener buttons on the a-pillar.....unrelated to the cargo cover.
think I used 11/16 or 19/32 plywood. then covered it with bed liner.
the vertical pieces are to keep it sturdy and now I have the ability to put things on top of it and tie them down. without them it would not hold a lot of weight.
for the back I just attached it with a hook and eye locks. 1 on each side. 1 in upper middle, and I used the 2 cargo d hooks and an hook on the bottoms. that way if I have larger cargo I can just in unhook them and take the back piece off. I don't know if you can see it but the back piece also folds in half (vertically). so if I only need a little more space I can unhook 1 side and fold it over and still keep 1 side hooked up.
yes those other pics got put in there when wastrying to fix the original pics. other projects completed. heated seats and garage door openers.
I also put in a reverse camera in my tow hitch cover.
My take on a cargo cover
Rather than using plywood like most that I've seen, I opted to use 1/8" aluminum that is braced from underneath. It's fully enclosed in the front and is usable as a cargo shelf for if I have the soft or hardtop on.
thatwhitejk (06-20-2019)
