My shot at a rear cargo storage box
...so you finally finished your box? It really looks nice. Came out super clean. I like it! Might have to swing by and check it out sometime soon. Let me know when we can get together (you can check out my fender chop and i can check out your box, and muffler relocation).
Great job, i am soooooo stoked on your mod!!!
Thanks a lot for all the comments. it's helps feed future mods.
Well some you guys asked for pix of the underside, here you go.
Just to answer some of the questions
I welded it in. Yes I plan on adding a steel locking top when I rino line the tub of the jeep. I didn't want to add it now because it would one look odd and two it would keep the carpet lid from closing all the way. Which most of you know by now would make it a PITA to close the back door. But yes, I already have a lid made up.
My exhaust was previously a mod, I just cut off the muffler and moved it to under the drivers seat, one I hate the trash can OEM mufflers and two I went with a flowmaster 40 and high flow cats. So NO I don't have strait pipes and the flowmaster sounds great I get compliments all the time about how aggressive my jeep sounds wide open shoting up the sand dunes. (even thou it's no V8, but wishing it was.)
so if there are any other questions just ask.
Oh and as for a pic with the BEER well i don't have one next time I load up I will, if I can remember.
But it does hold a 30 pack and a 20 lbs of ICE easy. I was a little scaried about the weight, but I just leave the drain cracked open, OH and I installed a Valve. ***just noticed the pics are before I installed the valve.
Underside, the step in the box is to clear the sway bar, which has been move back beacuse of the rock Krawler lift.
Passanger side looking a little forward.
same angle.
Drivers side looking forward
Another shot of the inside of the box.
Thanks again, for all the great comments and support. If i can help any one out with and answers just ask.
same angle.
Last edited by 915RUBICON; Feb 10, 2011 at 09:57 AM. Reason: Just adding alittle more
