projector retro fit
ok so here is my head light write up. as mentioned before i had plenty of time to work on these because hilldweller donated his old head lights to me. the projectors were ordered at theretrofitsource.com i had the hit kit already,but you can buy one for pretty cheap at ddmtuning.com they got one for about 30$
http://i767.photobucket.com/albums/x...2/IMG_0140.jpg http://i767.photobucket.com/albums/x...2/IMG_0139.jpg 1st step and probably the hardest was to bake the light at 270 for about 10 min to remove the lens http://i767.photobucket.com/albums/x...2/CIMG2636.jpg 2nd step was to trim about an inch off the bezel aswell as under the bezel to give the projector a snug fit http://i767.photobucket.com/albums/x...CIMG2641-1.jpg http://i767.photobucket.com/albums/x...2/CIMG2640.jpg 3rd i took a dremel and began to cut a hole. little at a time not to over do it http://i767.photobucket.com/albums/x...2/CIMG2642.jpg 4th i secured the projector to the housing using 10/32 screws http://i767.photobucket.com/albums/x...2/CIMG2643.jpg 5th i sprayed the bezels black. i want nothing to do with chrome. then i glued on the halo ring http://i767.photobucket.com/albums/x...2/CIMG2646.jpg http://i767.photobucket.com/albums/x...2/CIMG2650.jpg 6th i then sprayed the inside of the lens with vht spray tint for the blackout look. sanded it down with 2000 grit for a smooth finish. i sealed the lens back wired it all down. i connected the halos to my blinkers http://i767.photobucket.com/albums/x...2/IMG_0142.jpg and there you have it. for a little under 280$ you can make custom projectors. any questions i will be happy to answer. check out my other threads for more builds. http://i767.photobucket.com/albums/x...2/IMG_0138.jpg |
Very clean work, nice job.
In the process of retrofitting some BMW hi/low HID's to my H4 housings as well, thanks for the pics. |
What kit do I need to buy? Did you install ballasts, or is it just the projectors?
looks sick !! good job:clap:
Now you got Audi eyes, pretty cool looking :thumbsup:
Originally Posted by 07Ruby
(Post 1692357)
those are so ausome! i definatly am considering this
those are some sweet headlights
| All times are GMT -8. The time now is 06:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
