Rod Holder
Not exactly a modification to my JK, but thought I would share it anyway....
Finished this project today - My budget rod holder. The cargo basket is not longer balanced (might be bent a little from previous loads).... http://i75.photobucket.com/albums/i2...q/103_0101.jpg http://i75.photobucket.com/albums/i2...q/103_0102.jpg |
is it actually legal to drive around town like that?
Originally Posted by terrahawk
(Post 106620)
You must be minnow fishing with those little toys!:D
I like it but can you give me some details on how you made the holder? I was thinking something simmilar to hold my rods on the hitch hauler when we head to FL agian in August (if not before then and back agian in August).
nice, THATS why you wanted the front reciever :yup: i spend a lot of time at the beach with my jeep and i see all the fishermen with holders of some type like yours, good job :2thumbs: when your wade fishing i can see the sharks right next to ya....how? from above :yup:
http://i138.photobucket.com/albums/q...ephotos047.jpg |
(Post 106620)
Originally Posted by only_in_my_jeep
(Post 106625)
I bolted a piece of wood to the front of the cargo carrier, then cut 2" PVC into 18" pieces (using a chop saw). I used an air powered cut off tool to cut the notches for the rods. Mounted the PVC to the wood using 1" lag bots and 2" pipe straps (I think that is what they are called). They are $0.48 for 2. I think it was about $10 in supplies. The pipe was less than $5.00. I also used 2 'I' bolts (I guess that is what they are called) in the front so I can use bungee cords to strap the rods down if needed. Hope that helps. PM if you need anything else. Looks like you are not too far from Carolina Beach (Freeman Park). Have you been there yet? http://www.carolinabeach.org/site_ne...eman_park.html Joe |
Originally Posted by hurstrescue
(Post 106681)
The cargo basket is from WalMart. I have had it for a couple of years. I think it was around $70.
I bolted a piece of wood to the front of the cargo carrier, then cut 2" PVC into 18" pieces (using a chop saw). I used an air powered cut off tool to cut the notches for the rods. Mounted the PVC to the wood using 1" lag bots and 2" pipe straps (I think that is what they are called). They are $0.48 for 2. I think it was about $10 in supplies. The pipe was less than $5.00. I also used 2 'I' bolts (I guess that is what they are called) in the front so I can use bungee cords to strap the rods down if needed. Hope that helps. PM if you need anything else. Joe Good fishing too you. |
(Post 106754)
Thats why you alawys carry a bat with you out in the surf on the Natl' Sea Shore!:eek!:
