Old 09-23-2017, 01:46 PM
  #48181
mdiacity's Avatar
New lights came to wire up to new switches from OTRATTW
Old 09-24-2017, 11:19 AM
  #48182
Seabee CMC's Avatar
Installed Dynatrac Progrip big brake kit, what a difference that has made!
Old 09-24-2017, 04:10 PM
  #48183
chiapeteater's Avatar
Do those come with the wiring harnesses and relays? Could they be hooked up to an sPod?
Old 09-25-2017, 03:20 AM
  #48184
mdiacity's Avatar
They do not come with the harness. I contacted Rigid as my intention is to mount 1 set in my fog light brackets. I was told I will need to order DTP2 Deutsch connectors off Amazon. These can be wired to an sPOD but have a 3rd wire to light the backlighting. This will require an extra switch to activate then.
Old 09-25-2017, 05:14 AM
  #48185
Sponsoring Manufacturer
Dynatrac's Avatar
Thanks for going with Dynatrac! We're happy (but unsurprised!) you noticed the major improvement our ProGrip system makes! What kinds of fun do you have with your Jeep?
Old 09-25-2017, 04:13 PM
  #48186
Thank you for confirming this for me. It is exactly what I thought would have to be done, including the extra switch for the backlighting.
Old 09-26-2017, 11:49 AM
  #48187
CzechMate's Avatar
CzechMate-
I've got that same rack ready to go on, do you have any other pics of the distance between the rack and the body just above the mount? I'm not up for the body mount and the frame mount won't clear my bumper so I'm looking for options before I begin installation. If it doesn't look like it'll come together then she'll go to CL for someone else to use.
karls10jk,
here are some pics that hopefully will answer your question. If you were wondering as to if the hard top can be removed with this rack than the answer is yes. Here are some pics. Good luck.
ID:	675095   Click image for larger version
ID:	675096   Click image for larger version
ID:	675097   Click image for larger version
ID:	675098   Click image for larger version
Old 09-26-2017, 08:41 PM
  #48188
2qik2see's Avatar
Originally Posted by CzechMate
karls10jk,
Now that looks great! Was wondering how it'd look with the top off. Do you have to remove the rack to take the top off or does it tilt back??
Old 09-27-2017, 03:45 PM
  #48189
CzechMate's Avatar
No, I don't have to remove the rack to remove the roof. The rack is permanently mounted to the Jeep. I slide the roof straight back when the tail gate is open, there is just barely enough room so I gotta watch my fingers as to not pinch them
Old 09-27-2017, 03:54 PM
  #48190
karls10jk's Avatar
karls10jk,
Yep, that's perfect, thank you. I've got only soft tops but I need to recreate the mounts so it mounts to the bumper. The included mounts don't touch the frame with my current bumper and I'm not sold on drilling the body for it.
Do you get wind noise with the rack? I'm planning on this being my summer kayak rack and it'll go back into storage for the winter.
