Wrapping up the front end:
Drilling for the bump stop extentions http://project-jk.com/gallery2/main...._itemId=233422 Installing the bump stop extentions http://project-jk.com/gallery2/main...._itemId=233424 Installing the front EVO Plush Ride coils http://project-jk.com/gallery2/main...._itemId=233472 Installing the Bilstein shocks http://project-jk.com/gallery2/main...._itemId=233444 http://project-jk.com/gallery2/main...._itemId=233448 http://project-jk.com/gallery2/main...._itemId=233454 http://project-jk.com/gallery2/main...._itemId=233520 Marking the hole that needs to be drilled for the sway bar link extention bracket http://project-jk.com/gallery2/main...._itemId=233492 Drilling the hole http://project-jk.com/gallery2/main...._itemId=233496 Installing the sway bar link extention bracket http://project-jk.com/gallery2/main...._itemId=233502 http://project-jk.com/gallery2/main...._itemId=233544 http://project-jk.com/gallery2/main...._itemId=233594 Installing the front track bar relocation bracket http://project-jk.com/gallery2/main...._itemId=233512 http://project-jk.com/gallery2/main...._itemId=233516 http://project-jk.com/gallery2/main...._itemId=233526 http://project-jk.com/gallery2/main...._itemId=233534 http://project-jk.com/gallery2/main...._itemId=233538 http://project-jk.com/gallery2/main...._itemId=233504 http://project-jk.com/gallery2/main...._itemId=233592 Removing factory drag link http://project-jk.com/gallery2/main...._itemId=233522 http://project-jk.com/gallery2/main...._itemId=233524 http://project-jk.com/gallery2/main...._itemId=233548 http://project-jk.com/gallery2/main...._itemId=233552 Drilling the knuckle so that the EVO drag link flip kit can be installed http://project-jk.com/gallery2/main...._itemId=233606 http://project-jk.com/gallery2/main...._itemId=233610 Installing the new drag link http://project-jk.com/gallery2/main...._itemId=233556 http://project-jk.com/gallery2/main...._itemId=233612 http://project-jk.com/gallery2/main...._itemId=233616 Installing the front brake linke extentions http://project-jk.com/gallery2/main...._itemId=233596 The front end is complete! :thumbsup: |
Now on to the rear end:
Marking the rear factory control arm mounts http://project-jk.com/gallery2/main...._itemId=233330 http://project-jk.com/gallery2/main...._itemId=233352 Cutting off the factory control arm mounts and trimming the body mount http://project-jk.com/gallery2/main...._itemId=233332 http://project-jk.com/gallery2/main...._itemId=233344 http://project-jk.com/gallery2/main...._itemId=233342 http://project-jk.com/gallery2/main...._itemId=233338 http://project-jk.com/gallery2/main...._itemId=233348 http://project-jk.com/gallery2/main...._itemId=233370 http://project-jk.com/gallery2/main...._itemId=233374 Cutting off the passenger side rear control arm mount http://project-jk.com/gallery2/main...._itemId=233390 http://project-jk.com/gallery2/main...._itemId=233404 Grinding to a smooth finish http://project-jk.com/gallery2/main...._itemId=233380 http://project-jk.com/gallery2/main...._itemId=233408 After the grinding http://project-jk.com/gallery2/main...._itemId=233386 http://project-jk.com/gallery2/main...._itemId=233412 Fitting the rear control arm brackets http://project-jk.com/gallery2/main...._itemId=233436 http://project-jk.com/gallery2/main...._itemId=233438 http://project-jk.com/gallery2/main...._itemId=233440 After fitting and drilling, the rear control arm brackets are installed http://project-jk.com/gallery2/main...._itemId=233494 http://project-jk.com/gallery2/main...._itemId=233478 http://project-jk.com/gallery2/main...._itemId=233560 Here you can see one of the flagged nuts used on the rear bracket http://project-jk.com/gallery2/main...._itemId=233476 Installing the rear control arms http://project-jk.com/gallery2/main...._itemId=233484 http://project-jk.com/gallery2/main...._itemId=233540 http://project-jk.com/gallery2/main...._itemId=233558 http://project-jk.com/gallery2/main...._itemId=233564 http://project-jk.com/gallery2/main...._itemId=233568 Installing the rear track bar relocation bracket http://project-jk.com/gallery2/main...._itemId=233296 Installing the rear bump stop extentions http://project-jk.com/gallery2/main...._itemId=233566 Installing the rear EVO Plush Ride coils http://project-jk.com/gallery2/main...._itemId=233572 Installing the new rear sway bar links http://project-jk.com/gallery2/main...._itemId=233574 Installing the rear Bilstein shocks http://project-jk.com/gallery2/main...._itemId=233582 http://project-jk.com/gallery2/main...._itemId=233586 Installing the rear brake linke extentions http://project-jk.com/gallery2/main...._itemId=233588 And finally putting the tires back on http://project-jk.com/gallery2/main...._itemId=233620 http://project-jk.com/gallery2/main...._itemId=233624 The EVO DoubleD Long Arm is complete!! :clap: |
Here are a few shots of the finished product:
http://project-jk.com/gallery2/main...._itemId=233642 http://project-jk.com/gallery2/main...._itemId=233646 http://project-jk.com/gallery2/main...._itemId=233668 http://project-jk.com/gallery2/main...._itemId=233682 http://project-jk.com/gallery2/main...._itemId=233686 http://project-jk.com/gallery2/main...._itemId=233654 http://project-jk.com/gallery2/main...._itemId=233634 http://project-jk.com/gallery2/main...._itemId=233656 http://project-jk.com/gallery2/main...._itemId=233660 http://project-jk.com/gallery2/main...._itemId=233674 http://project-jk.com/gallery2/main...._itemId=233728 http://project-jk.com/gallery2/main...._itemId=233710 http://project-jk.com/gallery2/main...._itemId=233754 http://project-jk.com/gallery2/main...._itemId=233758 http://project-jk.com/gallery2/main...._itemId=233760 http://project-jk.com/gallery2/main...._itemId=233764 http://project-jk.com/gallery2/main...._itemId=233772 http://project-jk.com/gallery2/main...._itemId=233780 http://project-jk.com/gallery2/main...._itemId=233784 http://project-jk.com/gallery2/main...._itemId=233786 http://project-jk.com/gallery2/main...._itemId=233790 http://project-jk.com/gallery2/main...._itemId=233794 http://project-jk.com/gallery2/main...._itemId=233798 http://project-jk.com/gallery2/main...._itemId=233800 http://project-jk.com/gallery2/main...._itemId=233802 http://project-jk.com/gallery2/main...._itemId=233814 http://project-jk.com/gallery2/main...._itemId=233816 Congrats once again to the EVO DoubleD Long Arm Winners! :clap: http://project-jk.com/gallery2/main...._itemId=233819 |
:clap: :clap: CONGRATS! looks awesome! Can't wait to see some flexed out pics :wink:
That's very cool. Congrats again on a super prize. :thumbsup:
that's sick:rock:
Sam |
Sweet!
Now, how does it ride????? |
Congrats
Looks Great!:thumbsup::thumbsup::thumbsup:
Very cool and Congrats on the free stuff!
I see a loss of the tranny skid any plans for that? Which manufacture skids work with the EVO LA setup? I, also, see stock DS? Should these be replaced? I imagine so, but EVO's site makes no mention of it. Just that the exhaust needs worked. |
