JK Suspension This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler suspension components only. This would include items such as coil springs, shocks, control arms, track bars, relocation brackets and complete lift kits.
RE Hi-Steer / Bilstein Stabilizer / Dual Stabilizer / RE Trac-Bar Bracket (VA)
Old 03-03-2015, 05:06 AM
xp1ik05's Avatar
Default RE Hi-Steer / Bilstein Stabilizer / Dual Stabilizer / RE Trac-Bar Bracket (VA)
Have some parts i need to get rid out of the garage. All prices OBO. Call/Text 7577396922 for fastest response
Rubicon Express from axle side track bar bracket. Adjustable bolt to use without adjustable track bar. Light use maybe 10k. Have all the hardware and both side sway bar brackets. $50
Rubicon Express high steer kit. Maybe 5k. Used to raise drag link to the top of the knuckle and improve handling. Comes with factory pitman arm and half of the drag link. Tre going to arm is worn, moog tie rod end on knuckle side but I busted the grease fitting off it. I do not have the adapter for the knuckle after you drill it out but is only 8 dollars online. SOLD**
Dual stabilizer kit. Don't know what brand but have the shocks and brackets. 2 or 3 of the u bolts need to be replaced but everything else is there. Painted black but could use some touch up. SOLD**
Bilstein steering stabilizer with synergy clamp. SOLD**
Have 2 stock tie rods in great shape. One needs some love getting the adjustment sleeve to move easier and haven't messed with the other.
Have a complete stock suspension for a 2 door jk. All springs and control arms. Stock rear tire carrier with no light.
Will ship but the cost will need to be worked out.
Will have a synergy trac bar bracket next week once my truss is done being welded up.
Old 03-04-2015, 02:43 AM
xp1ik05's Avatar
Make offers. Need to move this stuff out of the garage
Old 03-04-2015, 04:13 AM
g8sfn's Avatar
Do you have pics of the Bilstein Steering stabilizer and synergy clamp?
Old 03-04-2015, 06:32 AM
xp1ik05's Avatar
Yes there is one up there. Text me if you need more
Old 03-05-2015, 02:43 AM
xp1ik05's Avatar
Buy this stuff!!! Let me know if you need more pics or any other info.
Old 04-10-2015, 06:55 AM
tj2jkrubi's Avatar
PM sent about the Bilstein stabilizer and clamp. Very interested.
Old 04-12-2015, 04:14 AM
xp1ik05's Avatar
everything is sold minus the RE track bar bracket
Old 04-12-2015, 06:33 PM
Tightdog's Avatar
Is this a raised track bar bracket? Used to raise axle side mount when performing a drag link flip?
Thx
Old 04-16-2015, 04:27 PM
xp1ik05's Avatar
Yes it is, not required to run a flip with it but does make things nicer.
Old 08-17-2020, 01:45 AM
AndyAnderson66's Avatar
What is the best steering stabilizer for Jeep JK?
Quick Reply: RE Hi-Steer / Bilstein Stabilizer / Dual Stabilizer / RE Trac-Bar Bracket (VA)
