2012 Rubicon- will 37" Km2's fit??
Flat fenders, Rock sliders and pinch seams trimmed, 2" spring spacers front and rear, and bumpers chopped. 4.5" backspacing on the wheels. Will 37" KM2's fit?
With flat fenders and 2" of lift and being that the 37" KM2s will probably measure 35.5" while on the Jeep, they'll fit easy. 35s fit on a stock JK with no lift and flat fenders, hell they fit on with stock fenders too lol
10/4- Thanks
Check out Metal Cloak fenders if you want to clear 37s with next to no lift.
1 Attachment(s)
Attachment 395372
Factory rear springs Factory front w 2" spacer 37mtr Trimmed pinch seam It is low I took off rk2.5 springs and am going to put teraflex 1.5" on |
3 Attachment(s)
Attachment 395847
Attachment 395848 Attachment 395849 Brand new 37" KM2's. barely rub fully stuffed. |
Originally Posted by Rubi-Cons
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=395847"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=395848"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=395849"/> Brand new 37" KM2's. barely rub fully stuffed. |
I must be an exception. My 35" BFG rub there with my TF 1.5" kit.
My 35" bfg km2 also rub as well on the pinch seam/rubi rock slider. 37s wouldnt even turn!
And i have the teraflex 2.5 coil lift with shock extenders These damn tires only measure out at 33.25" When its sitting on flat ground i cannot get my fingers between the slider and the tire. |
Must just be you guys then, cause I put 35" KM2s on my fiances with no lift and it only rubbed on the front valance (airdam) and that's it. Then I put a 3"/2" lift on it and never had any problems, now it's got a 5" lift and it needs 37s at least lol
