4 Door JK roof rack
4 Door JK roof rack
Just got my JK in the fall I want to put a rack on top. I have been shopping around I have kayaks and snow boards and use both tops (hard soft). What is great all around?
For a quickie type rack, the Thule system mounts to the rain gutters on the hard top & the door surrounds on the soft. They also make a rollbar mount. However, it won't work on the soft top with the top up.
It all depends on what you're willing to spend. GOBI & MBRP make great racks but they're expensive.
Ya I was looking at the MBRPs they looked pretty sick. I could only place I could find them through was quadratec and shipping to Canada was a bit steep but that's just the way it is. Thanks
I really like my Warrior Products rack. I can fit 2 canoes's with extensions or up to 7 bikes. Most offroad trips it will hold long items like canopies, fishing rod case and other lightweight gear that is bulky or just doesn't fit in the back. Going forward I may not use it as much for trips as I now have an off road trailer, but it's very useful around town to haul lumber, PVC pipes, etc.
The only issue is that it doesn't flip up to lower a soft top, but not a big deal as it's usually too hot to lower the top, so I leave it up to give me shade. To remove the top, I unscrew the arms in the back, unlatch it and slide it out. Prtetty easy to do, but certainly not as easy as just folding it down.
Nothing on it
1 canoe, 3 bikes (bike holder is DIY. I used 2x4's, bolted fork blocks to them in a staggered pattern, then use U bolts to hold down the 2x4's to the rack. It's a tight fit to get 7 bikes, but works well.)
2 canoe set up
Nothing on it
2 canoe set up
Loving my Garvin Wilderness Rack here...it can roll back so I can pull the hard top off and put the soft top on.
Attachment 154871
Attachment 154871
Is this the model which requires no drilling? Does it use existing bolts?
Thanks in advance.
KD
