Best Hardtop Hoist System?
#21
I really like my Harken Hoister, best mod I have done because it works great and wasn't expensive. I'm always parked under, its been hanging there for over a month, its really secure. It wasnt the easiest thing to install, but so completely worth it. I can take the top on and off with just me there. I will also hang my soft top on it when it gets cold out.
#22
4 eye bolts in the ceiling joist and 4 ratchet straps, 20 bucks later I was set, it is not hard or time consuming to do it. Better than dropping 300+ on a powered hoist IMO
#23
#24
do you have a pic of this? how do you slide it on w/o scratching it?
#25
It's U-shaped, level with the top of the tailgate. The top is carpeted so it doesn't scratch anything and the top slides off easily. The legs are wide enough that I can pull the front of my wifes car under it with a few inches on each side. Let me see if I can find the write up thread on it for you.
https://www.jk-forum.com/forums/show...light=hard+top
#26
I am confident in the boards and the lag screws but I was also concerned about the pigtail screws, eye bolt, etc. so I understand where you are coming from. I check them periodically and they have held up great. When I do store my top for a good amount of time I do have some "safety" ropes I use just in case the eye bolt gives or something goes with the rope cleat. Those just run from pig tail to pig tail. I also think it's worth it to purchase a marine rope tie off which I bolted to the wall for some extra precaution. So far I have been very happy with the set up. I have very tall garage ceilings so it really is up and out of the way. Mine has been hanging on the ceiling since March.
#27
Attachment 199269
#28
I can get you pics when I am at home, simply put eye bolts into your studs on the ceiling (obviously measure where you will want them in relation to your jeep) then put the ratchet straps at the corners. I used 12' which leaves a TON of slack line, if I buy another set I will go 8'. To take the top off I start w/ the front, lift it up to insert the ratchet strap into the bolt hole for the front, ratchet up a little, as you do this to both sides the rear will un-seat (but not slide) which allows you to move it up and place the other ratchet strap hook (ensure a padded hook) onto the back in between the corner and the gate and repeat. Once you have all 4 sides lifted a tiny bit go around to all 4 sides lifting a little at a time until your desired height is achieved. Then just carefully drive out of the garage w/o the top. To lower just repeat in opposite fashion. Takes me about 10 min. taking my time, no scratched to date. I will post pics soon
#30
