Cannot remove hardtop
The last two torx screws are jammed. Like hyper jammed. And I don't wanna strip the head. Any pointers? Much appreciated.
WD-40 maybe...?
Tried. And literally not budging a bit. It's never been this difficult.
Tried getting at it from the bottom? Maybe putting some counter torque on what the bold screws in to will help. I would recommend channel locks because of the shape.
are u using a ratchet or a srcewdriver?
once you get them off,,look into these,,i bought them and no leaks or problems what so ever. Cool Tech LLC. Hardtop Quick Disconnect T-Bolts |
Originally Posted by JK4x4wrangler
(Post 3006218)
Yeah. It's definitely sealed off from the bottom. But the ratchet isn't giving me leeway either. I'm still working at it between checking the thread.
Did you put it on too tight? How did it get stuck?
Did you try putting the others back in and tightening and then try to remove these last 2 frist?
On my 08 the bolts screw into some rectangular shaped nuts that slide in and out of slots in the body, There is not a lot of room to get into where they slide in and out of but enough you might be able to but a little torque on them.
Originally Posted by stormtrooper75
(Post 3006227)
i dont believe you can get at the bottom of this,i think its in the body. i might be mistaken though.:beer:
