D Ring Shackles
Where do you get shackles for your bumpers?
Is there a specific size rating needed? |
4wd Parts. About $12
Found mine at my local Autoparts store from what I recall they are 3/4".....Remember to pick up some Ballcock washers to place on the d-rings to keep them from clanging around.:bleh:
I see some are rated for 4000 lb winches and some are for 5000 and over. You guys seem to recommend the smaller. is this true?
Originally Posted by toad
(Post 1820662)
ballcock shank washers. >:->
Thanks toad...forgot about the Shank....what a name for these washers...:rotflmao2: |
Go to Agri Supply. They are 5 or 6 $'s a piece. Get a 3/4". They rated for 9500 lbs.
If you plan to use it, just make sure they have the WLL(Working load limit) stamped on it. And they are made in the U.S.
(Post 1820662)
And scene...
