GPS mounting location
In California we can only mount or GPS units in the lower corners of the windshield. Otherwise you're subject to a citation. I don't like the corners because that means a sloppy cable strung across somewhere. And those little tweeters are in the way too. All the surfaces in my 2011 JK are textured... How and where are other folks mounting their GPS units?
1 Attachment(s)
Attachment 378631 |
I had the same issue with the wire running all willy-nilly
over the dash... then a friend cam over and showed me how the whole dash comes apart on my 2012 JKU. :thumbsup: There is 1 screw under the dash directly below the steering skirt. The rest pulls right off. After removing the screw, start on the far left side,(driver's side) and pull each section off. The hardest part was snaking the charging cord back out to the 12v port. given some time I would have figured out how to hard wire the cord behind the dash. hope this helps. Sorry I don't have any pics at this time. Next time i rip it open, I'll be sure to post a how-to...on this subject. |
I ordered some RAM ball and socket mounting parts from Amazon and used the mounting screw in the top tray to secure it. Works great! Easy to remove and just run the cable in the area between the dash and windshield. Dont have pics available, but they are posted on another site.
