Help.. Smoke while towing
So I was towing some guy that got stuck at the beach and I was pulling him gently 1st gear around 3000 - 4000 revs and smoke started coming out of the hood on the front right side. I was on 2wd when I pulled and my temperature indicator didnt show any signs of overheating.... should I be concerned or no?
Thanks for the advice.. I just drove it around town for a while to see if all was good and it's looking ok... a weird smell though, kind of similar to burnt clutch
https://www.youtube.com/watch?v=eFHwzmzt8GE&feature=youtube_gdata_player
Towing or doing burn outs? Lol
If it's a manual, I'm guessing you effectively resurfaced your clutch by buffing it with the engine's flywheel. There's only so much magic smoke that comes out before it won't work anymore, and the magic smoke can't be put back in. When pulling, you need to use your gears and momentum. It's the vehicular equivalent of "lift with your legs, not your back."
If it's an automatic, you probably baked some tranny fluid in the torque converter. The JK does not have a trans temp gauge and I'm not even sure it's got a warning light.
If it doesn't, then it's an older model that hasn't been taken in for recall to implement one in software. But, I think OP was putting too much stress on the clutch in a manual. It may be old and starting to slip. If so, now it will get worse that much faster.
It's a manual trans 09 jk. The drive now is fine... I just get the smell from time to time though and the god damn death wobble which I need to get fixed
