Hummer Suspension Vs the JK
Old Mar 24, 2009 | 12:55 PM
charlope's Avatar
Default Hummer Suspension Vs the JK
What makes the JKs suspension Better then the Independent suspension in an off road situation? What makes it Worse?
I am looking for positives and negatives as well as the different offroading situations it applies to
Old Mar 24, 2009 | 12:58 PM
saltman's Avatar
Independent suspension in terms of the Hummers (not prerunners) has no articulation. The wheels will be off the ground on hills. Spin them hard and you will destroy that rear locker when it catches. It also kills your traction, stability, etc. The Jeep's suspension allows the wheels to stay in contact with the ground.
Independent suspension is also hard to lift. They typically have a goofy bracket that kills your ground clearance.
Old Mar 24, 2009 | 01:35 PM
db09JKU's Avatar
IFS used for higher speed, controllable and ride comfort.
I always saw independent suspensions on trucks as higher speed use setups. If you were on a baja type race, the independent is what you need. Rocks, trails, slow, solid axle for those off camber, and clearance needs.
No real data on that, just always been my thought process, we will see if I am close!
Old Mar 24, 2009 | 02:26 PM
Atl JK's Avatar
No, that's pretty much correct. Although, I have seen a few high dollar rock buggies with IFS and IRS. Definitely not the norm though...
Old Mar 24, 2009 | 03:22 PM
4x4jkx's Avatar
Independent:
Pros: Comfortable, better control on road, etc., useful at higher speeds.
Cons: Worse articulation, PITA to lift.
Dependent:
Pros: Better articulation, more ground contact when climbing obstacles, easier to lift.
Cons: Less comfortable, feel every bump, not as useful at higher speeds.
At least that's how I was told.
Old Mar 24, 2009 | 05:11 PM
ACLM's Avatar
My wife has had an H3 for 2 years and I have only had my Rubicon 2 weeks but I would agree with the previous posts. Of course I haven't had either of them really "wheeling". Just mild mountain stuff.
Old Mar 24, 2009 | 05:18 PM
Yoda's Avatar
Important point: The suspension of the H1 is much different than the H2-3.
Old Mar 24, 2009 | 07:02 PM
ACLM's Avatar
True. I guess I didn't know which Hummer this thread was referring to. My bad.
Old Mar 25, 2009 | 07:09 AM
db09JKU's Avatar
With out a doubt, I have seen on offroad TV there are some sick, I mean SICK buggies with IFS or IRS that are rock crawling. But those are specific built.
