Jeep problem!! Please help
Looks like the drive shaft is too short for the amount of lift. Did you fully droop the wheels when it fell out?
This is what that is supposed to look like:
http://image.fourwheeler.com/f/14844...boot_joint.jpg
Note that your driveshaft has pulled out of the rubber membrane, which seems to have disintegrated or just flew off. The interior of that is filled with grease, which usually as the DS fails spits past the membrane as it gradually tears apart. An occasional inspection under your Jeep, especially if it's lifted, can help to catch these before they become catastrophic failures.
At this point I'd say to fix it properly you need a new driveshaft--preferably an aftermarket one designed for the pinion angles your lift has created. I recommend Tom Woods, though there are other good manufacturers out there as well. Whichever you choose, you want one that will custom cut the length of your driveshaft to fit your lift. They will ask for measurements. If they don't ask for measurements, recommend that you find another DS vendor. After installing the new DS, you'll want to check your pinion angle and ensure that you have it set up for the new shaft. If not properly set up you may experience very light steering wheel feel (like driving on ice) or seat-of-the-pants vibration at higher speeds. Correction for these usually involves adjustable control arms so you can adjust the pinion angle.
If all of the above is Greek to you, recommend that you find a good shop familiar with setting up 4WD vehicles. And, if you used a shop for your lift install--to be honest, I'd recommend avoid them. It really appears they sent you out the door with a set up destined to fail. They should have known that the Rzeppa joint would not handle the demands of your lift. Shame on them.
What do you mean by fully drop the wheels??? I bought this jeep lifted like a year and a half ago and the only thing ive changed are the tires and wheels (around a month ago) which are the same size as the ones before
BTW, if you want to drive your Jeep, you should be able to pull the front driveshaft by the removing the four bolts at the front differential (the rear of the DS seems to have taken care of the tedious part of pulling that shaft for you, LOL). It's okay to drive around in 2WD, assuming you've not damaged anything else with that DS flopping all around. If you try and hear further odd noise, then there's more amiss. But I think you'll be okay.
It looks like the CV joint at the transfer case came apart. I am guessing that the slip joint in the center of the driveshaft is bound from age (Rust, dried up grease, etc.) and put stress on the CV joint. The slip joint allows the driveshaft to change length as the axle moves up and down. If you unbolt the front of the driveshaft from the front axle and remove it, you can drive the jeep until it can be fixed.
