JK Fuel Economy
I averaged about 16-17mpg driving conservatively in mixed suburban conditions including highway road trips etc. for the first ~20K in my Jeep with stock Sahara wheels/tires (32" Bridgestone Dueler), no lift, [virtually] no other mods, etc. This is a '15 JKU with a 6-speed and 3.73. I can't see any way on earth you could get 22mpg consistently unless you set the cruise at 45mph in 6th gear and drive about 50 miles in a row that way. Normal conditions? No way.
I just recently put 33" tires on, ATs similar to the stock Sahara tires, and I'm getting about 15mpg.
I just don't see consistent 22mpg even with stock tires to be reasonable under ordinary driving conditions.
Agreed 100%.
Then, I hooked up the programmer I bought when I had it regeared and the tire size was set to 33.5. For S & G, I set it to 34. I can't explain it, but everything SEEMS to be correct.
Originally Posted by CarriageTownJeep
Correct me if I'm wrong, but if the tire size was incorrect, it would log miles faster than it should, no?
Have you calculated the fuel economy the old fashioned way using the odometer and fuel pump when filling up? I wonder how those numbers compare. I think the computer calculation is often off my some amount.
Absolutely. Always at least check it to verify. Never been off by more than 1MPG (usually only a fraction thereof). Plan to take it tomorrow and do the measured mile.
On another note, its strange there are no searches producing "fuel economy" threads? I've participated in dozens over the past 6 years...The best thing that came out of all of it for me is: 1) turn off the traction control and save 1-2 mpg, and 2) if mileage counts, put smaller, thinner, stock tires back on your vehicle and run two sets of rims/tires.
You've got read-out error. Report back the actual mileage as calculated by actual distance and actual fuel consumed. I'll guess 14-15 mpg.
you need to check reading over a full tank to empty tank...not a 20mile run. Hell I can reset mine and run 20 miles on a flat freeway and get 20mpg on my 37's and 5.38's but in reality over a full tank I get 14-15ish
measure the tire as the jeep sit on the ground (probably a 33.5in tire) put that in your programmer and run a full tank to empty
Either you're driving a unicorn, or something about your measurement is off. After many of these threads, I almost always see it coming back to 14-18 MPG depending on load and speed driven.
