Jk manual not engage at all when engine on!
Jk sahara 2013 manual
Gear wont engage if engine on!
It will engage if engine off!
Clutch pedal very soft and lose!
I change the clutch master cylinder & slave cylinder and not yet solved!!
Please help me
Please help me
For the sake of completeness: Why did you replace the master and slave? If it was because of this problem, and you've checked for visible fluid leaks and there are none, then it may be time to pull the transmission and take a look at the clutch and pressure plate. But! I've had to bleed my clutch system a couple times and have found that at first I need to drive it around pushing a couple times to get the clutch to work. But, that after a few miles of working the clutch like this, it gradually gets its old feel back.
