Long arm install gulf coats
Control arms I've never done but a buddy did his rk ones while I installed my tf 2.5 didn't seem too difficult. It seems like it's just a matter of bolting stuff in like the 2.5... I don't see how the 4" is much different with the exception of welding in brackets and of course getting rid of the stock ones first. Which since I'm a welder it shouldn't be to difficult to put some beads on a frame.
Youtube some installs if you are nervous or uneasy about it.
It really does not matter if you have 4" of lift, 2.5" of lift, or no lift. You are going to be removing the axles and all of the suspension to install a long arms kit and putting the suspension back on when you are done. You don't save any labor by installing the new lift first other then some slight tweeking of track bars and drag links to straighten the steering wheel and centering the axles. Trust me you will want to get the jeep on a lift to work on a long arm. Cutting off the old brackets and welding on the new ones is a major pain in the ass and is even worse if you are lying on the ground.
And I only said all that because I remember my long arm install a few years ago resulting in shitty cuts on the factory brackets, even shittier welds and days worth of extra work just from trying to do all of it from the ground...
Well my brother has a lift I can use at his work but that means it has to be completed or at least able to roll out in a weekend. Still if I'm having a shop do it I'd like to know of some in my area. I don't trust any random shop or a 4x4 truck shop to let mine be a first time.
I weld and do carpentry for a living but it's to government standards so that probably means I'm not that good. As long as I have a foot around everything for the stick it shouldn't be hard.
If no one can suggest a shop I'll just have to look while I'm home in May. Might just keep the tf 2.5 for several more years and save up to have a shop do it.
Is it all still together and functioning lol?
