MV-50 hose length
For those of you who have one mounted under the hood, did you find the hose length to be sufficient? If not, how did you rectify it?
Thanks! http://ecx.images-amazon.com/images/...500_AA300_.jpg |
Nobody has one?
i have one, but its not hard mounted.. i pull it out of the bag when needed..
the only tire thats a bit harder is driver rear, because batt is on pass side. |
(Post 2491660)
Originally Posted by robertgreen79
(Post 2491664)
Thanks! I was going to mount it under the hood and hardwire it. Looks like I'll need to get some sort of fittings and a longer hose.
i dont believe that comp is water tight, so it might get damaged with underhood mount.. also u could just get the correct couplers, and get a 25' gates hose, like the kind in a shop. |
1 Attachment(s)
I mounted one of these on the Sinister Fabworks bracket that mounts on the brake master cylinder.
Included hose barely makes it to the spare on my Unlimited. Stretched out to the max... 4 tires on the ground are alright tho. Attachment 202209 Be careful with it tho. First time I filled all 4 tires the compressor got hot (to be expected) and a poorly soldered connection on the motor let go. 30min of take-it-apart and fix crappy chinese soldering and it has been fine ever since. |
I changed the junk hose and connectors to standard NPT stuff and get a better, longer, hose. FWIW, I used the Sinister Fab bracket, too.
http://tslewisz.smugmug.com/Cars/My-...23181740-M.jpg |
Are they even weather resistant? I have one and have always thought about mounting it under the hood.
The compressor head run's real hot on these enough to burn your fingers, better put a heat sink on it unless you like getting burned
33 |
Originally Posted by 33 williys 77
(Post 2492264)
33 |
