My 08 has starting issues
Old Aug 8, 2014 | 08:58 PM
RufusTheTank's Avatar
Default My 08 has starting issues
My 08 won't start from time to time, I'll mess with the shift knob and then it will start, weird, anyhow.. We're looking in to getting a 2011 jku, do other years also have this issue? Or just the 07s and 08s?
Old Aug 8, 2014 | 09:23 PM
Mountain Man Tim's Avatar
depending on if its a bad ground or the park sensor it can happen to other years/models/makes. theres a few easy fixes on this very forum for the common jk versions of the problem.
Old Aug 9, 2014 | 06:15 AM
NFCastle's Avatar
My auto 07 has done this a couple times If I switch it into neutral rather than park, it fixes the issue.
If you have a manual, not sure what you could do!
Old Oct 22, 2014 | 09:43 AM
JK09MAN's Avatar
Default 09 4door wrangler unlimited
Hi. My name is kenny and in having the same issues.. First started 2 years ago and progressively got worse to where I replaced my starter a month ago and battery yesterday.. A transmission specialist friend of mine said it could be a cpu relay issue.. Idk.. Frazzled here in NJ
