Narrow tires v. Wide Tires
Very good and informative piece. Will be influential in my future tire decisions.
Also, pretty sad the number of folks that simply laughed at the length... Passing on some great reasoning. :/
The important part:
I agree with those who criticized the length not of the article, but of the post. All that was needed to get the arguments/discussions going is the above quote. By including the entire article, instead of just a link for those interested in reading it in its entirety, you discourage the discussion.
Oh, and I'll start it off: Wide, fat tires look cooler than tall, narrow tires. In the U.S.A. that is EOD (End of Discussion). LOL.
"When driving off-highway, the performance of a vehicles tires is influenced by the elements of friction as related to the following items: Adhesion, momentary molecular bonding, deformation and mechanical keying (Haney, 2003). Where a race car operates on a highly tactile surface, which allows wide, even smooth tires to perform exceptionally (due to adhesion and bonding), an off-highway vehicle operates in the exact opposite environment, with minimally tactile surfaces. Rocks, dirt ledges, dusty boulders, highly irregular surfaces, sandy washes, etc. occupy the fourwheeler's environment. Surfaces that do not provide high adhesion rates or momentary bonding. However, these surfaces are highly irregular, which does provide the opportunity to take advantage of mechanical keying and deformation. These traction elements require high contact pressure, coupled with low air pressure to get the tire to flex with the terrain. A wide tire distributes the vehicles weight over too large of a surface, preventing deformation from occurring at the same rate as a narrow tire with the same pressure (force). A narrow tire will hold better than a wide one by keying to the surface aggregate due to the greater vertical force."
any tires with an aspect ratio over 80 will work great off road with a good potential for air down.
37/12.50R17 has an aspect ratio of around 80.
unimogs and military trucks uses tires with aspect ratio of 80 like R16 and R20 tires.
I started to read it, then I finally started thinking how long is this thing. I then started scrolling down as curiosity got the best of me. I then realized if I read it I wouldn't finish reading it until tomorrow so I gave up. :eek:
Sent from my hand-held Go Go Gadget Contraption
Good read, seriously guys not all that hard to get through. Maybe it was easy for me because I will be buying tires soon. I like the idea of skinny tires, especially in snow. This is why I'm leaning towards pro comps, it looks to me like they run a little skinny.
