New JK ---26.8mpg Sweet!
Old Jul 10, 2008 | 06:26 PM
  #21
NE Wrangling's Avatar
I'm getting 17 on avg over 5 tank fulls. I have a 4dr, with 6speed, 4.10 gears and 35" tires. I do notice it dropped when I played with the tire pressure by 1 mpg avg. The tire place had them set at 40 lbs and I'm running 30 now. Tires max is 60 according to manufacturer.
I'm going back up to 36 as this is what felt best.
Old Jul 10, 2008 | 06:35 PM
  #22
AZJeeper's Avatar
Community Favorite
Originally Posted by jldx75
Nope don't trust the computer.
Next time you fill up, make sure the pump nozzle clicks off a couple times and you know your tank is absolutely full of gasoline. Then write your odometer mileage reading on a piece of paper and scotch tape it to your dash. Now drive the next 250 miles or so as you normally would, so that the gas tank is getting low, but your not risking running out of gas. You can guarantee that pretty much by looking up your gas tank capacity in your car's owner's manual and figuring out how many miles you could go even if your gas mileage is at the low end of the manufacturer's specification for your type of highway and/or in city driving pattern. When you finally fill up your gasoline tank the next time, simply record the current odometer mileage and having made sure to fill the tank completely full again as above, record the exact number of gallons required to fill the tank up (shown on the pump). Then subtract to find out how many miles you drove and form the quotient of the number of miles driven divided by the number of gallons used. That is your miles per gallon gas mileage.
Fine, except:
1. DON'T top-off. It will screw up your evap canister for sure! Also the vapor recovery system in the nozzle (if your state requires them) might actually suck some gas back out of your filler neck if it's that full. Free Gas! (for the station).
2. DO this method over several tanks. It's more accurate and you don't have to worry about toping off.
By keeping my mitts off of the MPG reset button between fills, I found out mine is reasonably accurate (+/- 1 MPG).
Old Jul 10, 2008 | 06:47 PM
  #23
ronjenx's Avatar
Here in Maine, there is no east-west highway. So, going east-west is on 45 mph roads, no stop lights to speak of. I have found 45 nonstop miles per hour for a long time is optimal for good gas mileage. Under these conditions, I easily get 24 mpg. And it doesn't make much difference if it is in overdrive or not.
Old Jul 10, 2008 | 07:11 PM
  #24
SCJK08's Avatar
how many miles u got on ur jk
Old Jul 10, 2008 | 07:26 PM
  #25
cmpmacchia's Avatar
Wow thats great gas mileage! I'm getting at best 22 MPG.
Old Jul 10, 2008 | 07:27 PM
  #26
pearl-drum-man's Avatar
Originally Posted by RedneckJeep
MPG estimates are an "average" of several tankfuls. That is the correct method. You need to average out at least three tanks in a row to get a good idea.
X2. And I wouldn't recommend clicking the nozzle beyond the initial stoppage. You're not supposed to "top off" anyways, and I did it once on the JK and got a nice burst of gas all over the rear quarter panel.
Old Jul 10, 2008 | 09:23 PM
  #27
yetibear's Avatar
Your doing a little better than I am, under similar conditions,-- 50 mph two lanes, no city driving, sometimes slowing to 35 through little towns, hilly, good mix of gravel roads thrown in for fun--, I'm averaging a shade over 21 mpg right now. I'm figuring it at 21.2 as of today, my dash computer tells me 21.6, it's pretty close, I have not reset it since I've owned it.
4500 miles on a stock '08 Rubi auto.
It's not bad, but my '87 full size Blazer that I traded on the Jeep had a lifetime average of 17 mph, that was with a 350, 4 Spd (w/granny lo),on 31"tires, and I think it was 3.73 rears. So the 21 is ok, but it should be better. Then again I just got rid of an '89 FS Bronco, 351 W, auto, 33's, no idea what rears it had, I would have been thrilled to get 10 mpg's outa that beast.
So compared to the Bronco, I am truly thrilled, compared to the Blazer I think Jeep missed the boat. I would gladly take the Jeep with the 350 and 17mpg over the little 3.8 with 21mpg's......GIMMIE BACK MY CUBIS!!!
There is no real complaint in that, I have no problem with the 3.8, I just think it should do better compared with the big 8 in a 1500lb heaver truck.
Old Jul 10, 2008 | 09:32 PM
  #28
bigbluejk's Avatar
OMG!!! my X get 13ish usually. the other day I got 15.4 and I did a dance. I have 4.10s with 33s and auto.
Old Jul 10, 2008 | 09:46 PM
  #29
yetibear's Avatar
I feel your pain! The dealer got my old Blazer about 2 months before I finally got the Jeep, and I had to use the Bronco as my DD. I could drive and watch the fuel gauge going down. Had I gone straight from the Blazer to the Jeep I might feel more disappointed, but going from the Bronco, even with todays prices my fuel costs are almost cut in half.
Old Jul 10, 2008 | 09:52 PM
  #30
bigbluejk's Avatar
You have an auto Rubi don't you? what size tires? my tires must be the bad variable then. cause we both have autos and both have 4.10s.
