Rear tire carrier
#21
You're right, though. They're not indestructible. And yeah, it's silly that the stock wheel and tire exceed the maximum weight of the gate, but good bump stops make a huge difference in the interim.
#22
I would just delete the rear tire and carrier, take the money that you would spend on a spare you will likely never use and install an on board air compressor and a good plug kit. Better visibility out the back and saves some weight. OBA is nice to have so you can air back up on the trails.
#23
I've been driving nearly 30 years and I have had to use my spare one time to get home from work, once my wife ran over a brown paper bag on the road that contained a brick and it bent the wheel and knocked the tire off the rim, had to use a spare to get the car home then. I've plugged and filled tires out of emergency necessity out on the road a half dozen times. I'd have to say I've needed a spare more or to otherwise fix a flat far more often than I've needed, say, car insurance, air bags, or my seat belt. Definitely more than any Texan would need a recovery strap, a winch or 4WD. And probably at least as often as I've needed jumper cables. I get it, a spare on a JK weighs up to 100 lb or more so it's a big old fat inconvenience but it's hardly a waste to carry one. Eventually you'll need it. And just like the winch or recovery gear, your chances of needing it go up probably 100x if you drive off road.
BTW I also carry a plug kit and a big air compressor at all times. And a jump pack, and a recovery strap. Why the heck not? that one time you need it, you'll be sorry you didn't have it.
#24
To spare or not to spare is largely going to be based on your own experiences. It's like the D30/37's argument. You will have 50 guys come in and say I have been running my D30 on 37's on the hardest trails in the world and never had a problem then 5 dudes pop in and say their D30 grenaded as soon as they put it in gear on 33's. As I said to each their own. I like the look and the weight savings. It's a risk I'm willing to take knowing it could bite me in the ass one day.
#25
I mean, I kind of like having a vehicle that I know will get me pretty much anywhere I will ever need to go under any conditions I will encounter. The risk of having a flat that leaves me stranded sort of undermines that. But if your Jeep is an off-road toy then I can see how being stranded is not much more than an inconvenience. You hitch a ride back to some base station from a friend or use their spare, put the Jeep back on the trailer and take it home.
Horses for courses I suppose. I can definitely understand the "less weight" argument and I'm tempted to do that myself.
