Reduce road noise???
Old May 22, 2008 | 12:05 PM
Omega Man's Avatar
Default Reduce road noise???
Has anyone done anything to quiet down the interior of their JK?
I am trying to figure out how to cut back on the road noise. Any ideas? Did putting a liner on the hard top help? The BFG MT's on concrete roads @ 80 mph gets to you after a while
Old May 22, 2008 | 12:57 PM
only_in_my_jeep's Avatar
Run road tires.
Old May 22, 2008 | 01:06 PM
mikeyfl's Avatar
Old May 22, 2008 | 01:37 PM
brian_crystal's Avatar
Vet Army
Well, you could line-x the tub and then put the carpet back in. You could get the vehicle undercoated in something thicker than what they put on at the dealer. I had the local Ziebart place put sound proofer in the doors...just like the undercoating just a little thicker. This added some weight to the doors, but in a good way. There is a company that shall not be named that makes a liner for the hard top that acts as an insulator but also will deaden the noise. I am thinking a poncho liner would do the same thing. Ummm, you could get some of the expensive sound dampner stuff from Bestbuy ( I can't think of the name Dynamat, I think) and put that on your floor boards under your carpet. That would probably give you the best results. Do a google search for dynamat or sound deadner and you should come up with some cheaper alternatives. A layer of rattle can undercoating on the underside of your hood will help a little if you don't have the cloth insulation. Those will get you started at least.
Old May 22, 2008 | 01:42 PM
sully151's Avatar
Originally Posted by mikeyfl
Mine goes all the way to 11
Old May 22, 2008 | 01:51 PM
greenmachine07's Avatar
ear plugs
nah the tire swaps theo only thing i can think.
i personally love road noise
Old May 22, 2008 | 02:44 PM
Seryoga's Avatar
Sell it and get a Hummer
Old May 22, 2008 | 02:52 PM
Deviant's Avatar
two sets of tires help for sure if ya can afford an extra set of road tires...I plan on having a local shop line my hard top with some felt or something to deaden the wind noise, you can do the same to a soft top...and I want to line-x, or whatever the tub to help with noise.
Linning the hood is a great idea...never thought of it before
mikeyfl's Avatar
yeah, i was going to post:
but i knew someone would say that their radio goes to 30.
Old May 22, 2008 | 03:43 PM
wayland1985's Avatar
Dynamat..... the entire tub....... with 2 layers....
