removing stock front bumper
is it just me or on a 2013 is it ridiculously hard to remove the stock front bumper? ive spent about 6 hours trying to get it off now. ive finally got all the plastic stuff off now im down to the last 4 bolts that are connected to the frame? ive got the top two out they took about a good hour to get out with a ratchet after loosening with a wrench. now the bottom two im having absolutely no luck on what so ever they seem stuck on there. all of these bolts are just stuck like crazy. ive got it soaking in wd40 overnight hopefully it will budge in the morning is there any other ways to get those bottom two bolts off faster?
Originally Posted by sm0ke
(Post 3516641)
Originally Posted by RoysRig
(Post 3516686)
2012's should be the same, and I had no issues. Took 15 mins to get it off. Your's rusted already? I did use an impact tho.
(Post 3516696)
no not rusted at all. there is just not alot of area for me to get in there and loosen it up the frame is in the way in each side of the bottom two. this is my first time doing anything like this so im probably not doing it right but it seems it should be alot easier then this
all the tutorial videos im watching are showing them using some type of electric or impact wrench/ratchet to get those 4 bolts off. im starting to wonder if im gonna be able to do this without one ?
(Post 3516730)
Been a while since I did mine. But I remember the bottom plastic part came off first, then the main bumper plastic piece came off then all I had left was the metal part of the bumper left(the part with the 4 bolts). Once you have the 2 main plastic parts off I thought that pretty much opened things up to get in there. :thinking: Like I said it's been a year for me and it didn't leave a lasting impression on me I guess. I just know I saw that bumper sitting in storage today when I went over to start up the other toy.
If its like a 08 you just take off the plastic trim on top and the air damn off the bottom. Then you have four nuts on both sides. Just get the right length extension for your ratchet and you should good to go.
(Post 3516737)
Originally Posted by woodyvw9
(Post 3516743)
I will looking into a longer extension in the morning. I am having to use an extension now for it already but it might not be long enough. thanks for the info guys hopefully it will be off by after noon =/
seems like the hardest part of the new bumper install is getting the old one off lol |
