Rubicon Express Vs. Teraflex
I finally got the approval from the boss (GF) that I can lift my JK. I've been looking at the Rubicon Express 3.5 Super flex for about a month thinking that was the way I was going to go(w/ 35's). Now, I'm also looking at the Teraflex 4" and thinking I may want to put 37's on. I was planning my rig out for the RE Lift with 35's.
What does everyone recommend?
What other consideration's do I need to make if I go with the 37's with 4 inches of lift (i.e. driveshaft, etc.) that wouldn't have to with 35's and 3.5"s of lift?
I am also looking at the Teraflex 4" kit, 35s for now, maybe 37s next time around. Their customer service seems to be top notch. I was looking at the Currie kit as well, I've heard both are very well made.
Talk to David at Northridge, he has a lot of knowledge on all of the kits and gives great advice.
I live in Spring also. I run a 2.5" TF lift and love it. I found this in the modified section under FAQ's
Q: What are all the components that I will need with a 3" lift?
A: At bare minimum, you should have a set of 3" coils, bump stop extensions, longer shocks, rear brake line extension brackets, new longer rear sway bar links (factory links can be installed up front), adjustable front track bar and rear track bar relocation bracket. Optimally, I would recommend adjustable front upper and lower control arms as well as they will help you set your caster to the appropriate angle it needs to be. Also, if you have a 2-door, adjustable rear upper control arms and a new double cardin U-joint style drive shaft would be highly advisable.
Q: What are all the components that I will need with a 4" lift?
A: For a 4" lift, you should have a set of 4" coils, bump stop extensions, longer shocks, extended brake lines, longer sway bar links, adjustable front track bar, adjustable rear track bar, front and rear track bar relocation brackets, dropped pitman arm, adjustable upper and lower control arms front and rear and new double cardin u-joint style drive shafts.
I would also think you would want to look at gears. Sorry I forgot if you have a ruby or not but if not 37's will be a lot of strain on the front axle for a D30. Would also want to look at C gussets and axle sleves.
