Soft top cleaner
Hey everyone, What is the best soft top cleaner and vinyl window cleaner for jeep? I'm getting ready to order some and didn't know if yall had any suggestions on what to get.
Thanks, Jeremy |
:what?:
I really donīt know how to clean the soft top, does anyone know? Can I use this product: http://www.stp.com/appear_protectant.php Thanks |
303
303 Aerospace Protectant - use this before your top is soiled and you're good to go. If you're top is soiled you'll need the 303 Convertible Top Cleaner.
Unfortunately i didn't find this product until my top looked like it was 100 years old, but cleaned the 2years of red clay off as much as i could with the 303 cleaner and applied the protectant and it looks a heck of a lot better now. the folks there were very helpful and gave me a ton of info which i'll spam here. "Sailcloth" is a brand name that refers to the grain of the vinyl topping, not the type of material. The topping itself is vinyl. Here's the topping mfg's technical description of this type of vinyl topping, which is standardly used on SUV's: Single Texture - Sailcloth A two ply composite made of a PVC sailcloth grain outer layer and a polyester/cotton lining fabric. As for vinyl topping.....often a convertible top kit is not needed, just the protector. If your topping is soiled to the point where soap and water doesn't get it clean, then you'd need a specialized cleaner. Otherwise you don't. Once you start using 303 A. Protectant on a routine basis, it makes the treated surface EXTREMELY repellent to soiling and staining. Therefore a specialized clean is not needed between reapplications either. If you need a specialized cleaner because of soiling, 303's Conv. Top cleaner is a good choice. You can order that separately, by the way, instead of the kit....and it's more economical to do so. Here is text from a 303 pamphlet on proper care of standard top-coated vinyl (including VINYL topping) and also clear vinyl. http://www.303products.com/tech/inde...&feature_id=18 If you're technically oriented and REALLY want to know details about what clear vinyl is, how it's made, etc, here's a tech bulletin on that (a lot of 303's website visitors are enthusiasts who are interested in can't-find-it-anywhere-else information such as this). http://www.303products.com/tech/inde...ategory_id=117 Other applications for this product which may apply: http://www.303products.com/tech/inde...Product_ID=378 http://www.303products.com/tech/inde...Product_ID=312 303 PRODUCTS, INC. R. K. Dyer 800 223-4303 |
303 is good stuff! You can also use 3M leather & vinyl cleaner/restorer does a really good job as well.
