specs on cumming V6 that was list SEMA jeep last year
Dodge it geting this new engine in 2009 hope hope hope wrangler gets it too
The Engines
The new Cummins diesels are a 4.2L (256ci) V-6 using a 90-degree V-block design with aluminum heads and an iron block. They use single overhead camshafts, a new EGR system, a single turbo, common rail fueling with piezo injectors, and a diesel particulate filter. The V-6 weighs in at 663 pounds.
The V-6 is rated at 270 hp and 420 lb-ft of torque,. These numbers are not set in stone and may rise by the time theengines reach production. In a performance test using a Durango fitted with the Cummins V-6, the SUV reached 60 mph in 9.6 seconds.
The diesel V-6 achieved 22.1 mpg
Super-fast-acting piezo injectors are part of the reason the new V-engines are so efficient. By using crystals that change shape in .02 milliseconds when charged with electricity, the injectors are able to actuate much quicker than those driven by solenoids. This improves the accuracy of (up to seven) injections during the power stroke and the exhaust stroke when the particulate filter needs to be heated to clear out trapped particles. The downsides to using piezo injectors are the added cost, the need to use ultra-low sulfur diesel fuel, and slightly raised nitrogen oxide emissions.
Emissions
The battle against nitrogen oxides and particle emissions is the biggest hurdle for dieselengine builders who must deal with the stringent '07 federal guidelines that allow nomore than 0.07 grams of nitrogen oxides per mile and 0.01 gram/mile of particulate matter-aka, soot. In addition to the requirement of ultra-low sulphur diesel, a closed crankcase filled with low-ash oil, and the fueling tricks mentioned earlier, the engineswill use a particle trap, catalytic converter, and EGR system.
EGR (Exhaust Gas Recirculation)
The V-engines have cast pathways that cool and route exhaust fumes that are fed to theintake. The gases are used to cool the combustion process and reduce nitrogen oxides byintroducing carbon monoxide and water vapor (and everything else in exhaust) back intothe cylinders. Gases not recycled are sent to the turbo located in the valley of the engineV.
Variable Geometry Turbo
The turbo is a Cummins-built unit that uses an exhaust turbine that slides along an axis tovary the volume inside that half of the compressor. This technology maximizes spool-upat low rpm then opens the chamber when large amounts of exhaust are pumping out ofthe engine. The downpipe after the turbo includes a built-in catalytic converter that is thestart of the post-engine emissions controls.
Catalytic Converter and DPF(Diesel Particulate Filter)
That catalytic converter is a passive oxidation catalyst that's packaged close to the engine to provide a quick warm-up time and allow the engines to be easily packaged in SUVs and 1/2-ton pickups. The downpipe after the catalytic converter leads to a DPF with a ceramic honeycomb four-way catalyst that captures soot until it's rendered EPA-friendly. Sensors placed before and after the DPF measure flow and alert the engine when blockages are creating significant backpressure. When this is detected, the engine electronics will calibrate injections to raise the exhaust gas temperatures (sometimes injecting fuel during the exhaust stroke), which will burn off and catalyze particles inside the insulated chamber. Cost is a big concern with DPFs, but all light-duty diesels willhave them after January 1, 2007, and the DOE/Cummins tests proved the units will last for at least 150,000 miles and still be effective.
The Heads
The high-temperature aluminum cylinder heads include a single overhead camshaft to operate four valves per cylinder. The cams are chain-driven and use hydraulic lash adjustment. Some of the photos in the DOE/Cummins documents appear to show injectors mounted inside the valve covers that would help keep the engines quiet. All the parts of the heads are designed so they can be assembled before they are attached to the block. As mentioned earlier, the EGR system is cast into the heads to minimize the size of the engines and reduce the chances of exhaust leaks. Exhaust gases sent to the manifolds are routed through exhaust passages that are built into the heads which take gases up to the crossover manifold that leads to the turbo.
The Block
The cast-iron blocks are designed to be strong and incorporate accessories common withcurrent gasoline engines to reduce the costs of the diesel option in SUV and 1/2-tonapplications. The alternator, water pump, oil pump, an aluminum stacked plate oil cooler,A/C compressor, and the vacuum pump are mounted either to the block, the heads, or thefront engine cover. The oil filter is found near the bottom of the block at the front of theengine next to the pump and close to the oil pan.
Low-Ash Oil
Like all '07 emissions-compliant diesel engines with a DPF, the Cummins V-6 and V-8 will need to use CJ-4 low-ash oil. This prevents the DPF from becoming clogged, itsmore resistant to heat, and produces less sludge and soot than conventional diesel blends.
ULSD (Ultra-Low Sulphur Diesel)
Anything over 15ppm sulphur content will ruin the new Cummins V-engines. It's a fact of life for any truck using piezo injectors and a DPF, but ULSD will be your only choiceat public pumps by the time trucks with these engines hit the streets. In fact, you may already be using ULSD-check the pump next time you fill up.
The Bottom Line
The 4.2L V-6 and 5.6L V-8 engines that Cummins developed in cooperation with the Department of Energy look like a home run. They are strong, yet efficient, and they are very clean. Costs and noise have been taken into consideration and are likely to be the two biggest challenges to the success of these engines in the SUV and 1/2-ton marketplace. Who knows what fuel prices will be when these engines are available (hopefully, by 2010), so the superior fuel mileage may be enough to convert the spark-pluggers.
We can't predict what people will think in a few years, but we can't wait to see diesel engines in SUVs and 1/2-ton trucks. Just like the authors of the DOE/Cummins reports, we believe: "There is a path to market for the light truck diesel."
The Engines
Emissions
The Heads
The Block
Low-Ash Oil
The Bottom Line
I wish we could have diesel power in the States for our JKs...Heck I would even take a 250hp/375lb/ft 3.0 V6 diesel (if there is such a engine with these specs). I would think it would propel the JK nicely, then maybe with some tweaking get 300hp and 450lb/ft....I would think then the JK could move any wheel/tire combo you could think of.
