o2 sensor
Old 06-21-2018, 05:47 AM
jvalus's Avatar
Default o2 sensor
the engine light came on and i plugged my hand held tester in and the code came up o2 sensor.the only problem i have is after climbing under my jeep i noticed what looked like 2 o2 sensors on each side of exhaust system.i am not sure these are all o2 sensors,but i dont have a shop manual and im not going to replace all four,any thoughts?thanks
Old 06-21-2018, 06:36 AM
karls10jk's Avatar
You should have 4 o2 sensors, that's normal. Your code reader should point to a particular bank in which case you can replace the faulty one. Use only Mopar or NGK sensors, jeeps don't play well with Bosch for oxygen checking.
Old 06-21-2018, 10:11 AM
Mr.T's Avatar
Exclamation
Your profile says you have a 2018 JK -- Is that correct?
Old 06-22-2018, 05:53 AM
jvalus's Avatar
thanks karl,unfortunatly my code reader is not a top model,so im note sure which one or ones it is
jvalus's Avatar
no sorry,its a 2010 wrangler unlimited.thanks
Old 06-22-2018, 07:19 AM
karls10jk's Avatar
If the codes are still on then go to your local auto parts store and see if they'll read them for you- usually a free service and most stores do it.
Alternatively, you can cycle the key from off to on and on the third turn (towards on), leave it in the run position- the jeep should spit some numbers out at you. Please note- doors/ gates should be closed otherwise it may not show you the codes.
Old 06-22-2018, 10:05 PM
4x4chick's Avatar
My understanding is that there is a re-call on the 2009 to 2011 Jeeps O2 sensors. Found this out a month ago at the smog station. You might want to look into that.
Old 06-23-2018, 02:44 PM
jvalus's Avatar
auto parts store code reader came up with the egr valve, they had one but i didnt want to buy a duralast part,so going to buy the mopar egr,now all i have to do is find where the egr is located
Old 06-23-2018, 02:45 PM
jvalus's Avatar
thanks,it ended up being the egr valve,also,i havent received a recall notice
Old 06-27-2018, 12:07 AM
Mark Doiron's Avatar
You're not going to like the answer ...
https://www.jk-forum.com/forums/jk-w...-p0406-127376/
Be sure to read through the thread as folks added in suggestions, most especially if you have an auto transmission (I have a manual).
Edit: It looks like something broke the links to my images. Here's another write-up using my original images that may help clear up a few questions ...
https://www.jk-forum.com/articles/ex...r-mark-doiron/
Quick Reply: o2 sensor
