Maybe a Stupid Question. Hutchinson G Wagon wheels, will they bolt on to a JK?
https://cimg3.ibsrv.net/gimg/www.jk-...13011e276b.jpg
I know that JKs are 5x5. The g wagon hutchinson beadlocks look great in my opinion, but it doesn't appear that they'll fit. Does anyone have any experience with the wheels? It looks like they're 5×5.118. |
Are you sure about that 5x5.118 bolt pattern? There is a 5x118, but no idea what 4x4's would run that pattern.
5x127mm = 5x5 5x118mm = 5x4.6-something inches So, assuming they are 5x118, no they will not fit. |
Originally Posted by nthinuf
(Post 4343538)
5x127mm = 5x5 5x118mm = 5x4.6-something inches So, assuming they are 5x118, no they will not fit. Thank you for your quick response. |
You could run them with an adapter. It looks like you would need one anyway with the amount of wheel back spacing that wheel has.
Sweet, thank you. I'm assuming I can find them on 4WP, Extreme Terrain, Quadratec, etc?
Originally Posted by TheDirtman
(Post 4343553)
I doubt you are going to find that size on a reseller. This company will custom build what ever you want. They are local for me and I have used them several times I would get the wheels first so you can get exact dimensions for the hub bore as they build them hub centric for a perfect fit. They typically have a 5 day turn around.
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech |
(Post 4343556)
16" wheels fit the JK? i thought if they do then it is extremely tight and really limits steering upgrades.
Originally Posted by DEJK2012
(Post 4343562)
