putting Rubicon tires & wheels on Sahra 2015
Does it make a differance if I put a set of Rubicon wheels and tires on my 2015 Sahara? The Rubicon tires are LT225/75R17 and the Shara tires are P255/70R18, Does it change the speedo readings I don't know about going down from 18 inch wheels to 17 inch
You will be going from 30 to 32 inch tires, so it will affect the speedo and mileage calculations as well as shift points if you have an auto. As long as you're swapping both the tires and rims the 17 doesn't matter. I put my oem Moab 32s (17s) on my wife's Sahara Altitude but I believe she had 31s (18s) on there. The speedo difference was minor and she didn't want me to reflash it.
Here is the comparison...
Tire Size Comparison
If I remember right it wasn't even more than an inch difference. The BF Goodrich were slightly taller. It wasn't enough to worry about maybe 2 mph difference. I have since went to a 315/70/17 and had to change the tire size via a Procal.
The OP stated 225 75 17 which I think was a typo..."Rubicon" tires are 255 75 17, which is virtually identical in height to the 255 70 18s. You'll be good, no speedo correction needed.
I use them as Winter wheels.
I did notice almost a 10% difference in MPG though, the Rubi setup made my ride more thirsty.
