Tire/Wheel Noob Pls Save Me
sooo, I'm underway on my ship and I work during the nights whenever all the shops are closed for me to call and ask these questions.
when it comes to tires and wheels, what am I looking for to make sure they will fit? I'm wanting 315/70R17 Cooper STT Pro tires, with 17" Fuel Hostage wheels. the part i'm getting tripped up on is in: HOSTAGE 17-85 5:1143/5:127 14ET BLK what exactly am i reading? The only thing I know from this is the rim is 17" with the 5:127 bolt pattern i need. what else am I supposed to be looking for? what is and the importance of the offset? thanks again for helping this hopeless jeeper:rock: :rock::rock: |
Rim Diameter = 17" Rim Width = 8.5" (very common size for a JK) Dual Bolt Pattern (this is the number of wheel studs, and the spacing between them) 5x114.3 = 5 x 4.5" (other vehicles) 5x127 = 5 x 5" (Jeep JK's) 14 = offset (an 8.5" rim with 14 offset converts to 5.30" backspace) Stock rims have around 6.25" backspace. The typical recommendation for a 35x12.50 tire is a 4.5" backspace. Tires mounted on these rims will be moved out less than an inch, so you might expect 35's to rub when you turn. Good choice on the tire, I like mine. But, that specific size is E rated. Many people here consider E's to be a bit stiff for a JK, better for full size trucks. Can't say what 'your' opinion will be, so just a heads-up. (You can always run lower psi to soften them up a bit) There are two threads stuck to the top of this Modified area, FAQ's and Thoughts On Lifts. If you haven't opened them, might not be wasted time. |
| All times are GMT -8. The time now is 09:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
