accessories switches
Old Jan 25, 2014 | 03:03 AM
lonestar's Avatar
Default accessories switches
I am planing on mounting some lights to the windshield. I was curious to see where ppl were putting them. I was also going to ask if there is any switches that i can put infront of the shifter? where the traction control is. any thoughts please help out. thanks.
Old Jan 25, 2014 | 06:01 AM
redrum914's Avatar
Check my profile I did a little write up of something similar
Old Jan 25, 2014 | 06:03 AM
redrum914's Avatar
Picture of the switches. But if you only need two I'm sure you could drill them into the blank spots
Old Jan 25, 2014 | 06:11 AM
jfresh360's Avatar
I did something a little different, I put my switches on my side pillar.
Old Jan 25, 2014 | 06:19 AM
Jersey_Devil's Avatar
I used these in front of the shifter for my heated seatsClick image for larger version
Sent from my obama monitoring device
Old Jan 25, 2014 | 06:39 AM
catahoula's Avatar
I used the Daystar panel and switches. I believe mine is made for an automatic though.
Old Jan 25, 2014 | 12:25 PM
lonestar's Avatar
Attachment 526128
I like that set up... where did you get that? I am really digging that. Im sure i will need more that 2 eventually so I might as well get something that comes with multiple set switches.
Old Jan 25, 2014 | 12:55 PM
jfresh360's Avatar
Its the oem plastic pillar. There was enough room in the back to run the wires and put the switches in also.
Old Jan 25, 2014 | 01:55 PM
bad1chad's Avatar
This is the stock switch provided with KC Hilites.
Installed left of the steering column, where the rubicon fun switches would be.
Old Jan 25, 2014 | 03:27 PM
lonestar's Avatar
thanks yall. I really appreciate the info that yall posted. Its hard having a new toy with so many ideas and not alot of money lol.
