ATTENTION ALL 2010 JK's.. UPGRADED FOG LIGHT WRITE UP & PICTURES
Old Jun 22, 2010 | 08:07 AM
  #21
Jolly's Jp's Avatar
Did you have to add a relay when you hardwired? I know the px24 bulbs are 24 watts. Just looking around for a few ideas.
Thanks,
Kevin
Old Jul 13, 2010 | 09:31 PM
  #22
Kauaian's Avatar
Originally Posted by BLK-JK23
Okay some of you know that the 2010's have the absolutly shittyest foglights..
they use the PSX24W bulbs.. which are about as bright as a jar full of fireflys
The 2007-2009 use 9145's which are decent
done with the small talk.
I was eating a delcious pile of popeyes chicken after me and my buddy finished taping and wetsanding his ws6 trans am...
so after popeyes we went next door to the New auto zone.. and i was looking at retrofitting a new bulb in to the psx24w housing
but.. NO LUCK
I stumbled apon a set of fog lights..
Pilot driving lights. 4inch housings with h3 bulbs. i was hesitant on getting them thinking they were a pile of shit..
so i paid under debit so if they blew ass i would return them.
got home installed them and holy balls they are 2x as bright as my IPF headlights.
heres some shots.
i took the old fog light mount and it fit perfectly and screwed right on it..
the blue looks great in person and grew on me instantly and it provides white light.. NO BLUE
IPF920H4'S ONLY
PILOT FOGS ONLY
BOTH.
Another shot of playhouse
just ipfs.... see you cant see trees in background
here is both ipf and pilots
photos dont do them justice they were takin with my verizon droid..
what you will need to do.
first buy the PILOT PL203W from auto zone 39.00 EXCELLENT QUALITY with glass lense
throw pos stockers away
1.Take the Grill off the jeep.. Six clips
2.Take the center peice in between the bumper and grill... 2 clips in order to remove bumper and have room
3. take off bumper.. 8x 18mm bolts
than install old fogs outer ring and hard wire the new fogs in with disconnects and install everything back to normal.
thanks guys hope some follow my footsteps in this... they are EXTREMLY bright!!!
Cody
Another 2010 w/ bum fogs fixed
quick,simple,satisfied!
Thanks again for the writeup!
Old Jul 18, 2010 | 02:28 PM
  #23
Wow!! Those look really bright, and I think the blue will look great on my deep water blue JK. So I am a total newb to electrical stuff and I was wondering if this is an easy mod for me. Could someone tell me what this means: "than install old fogs outer ring and hard wire the new fogs in with disconnects and install everything back to normal." How do I hardwire them? What are disconnects? etc
Thanks everyone
Old Jul 18, 2010 | 04:52 PM
  #24
Kauaian's Avatar
Thanks everyone
in order to yank your stock fogs, you will unscrew it from the inside bumper (4 screws). now the stock fogs are attached to that hardware ring(you need that). unscrew that long screw, and pry the side of the hardware ring over the nipples. now your stock fogs are free! (not really) you will be forced to cut the two wires in order to free up your stock fogs and install the new ones.
you will have 2 wires- one black and one white/stripe(color?the light colored one. doesnt matter. just be sure to keep black with black!).
you have to somehow, connect the black wire(from vehicle) to black wire(from new fogs). the other wire(from vehicle) connect that to the white wire(from new fogs).
you have many ways to wire it. you can "hardwire" those wires by either getting cheapo wire connectors or soldering them together and protecting them with heatshrink.
I decided to make it "disconnectable" and soldered wires to female/male clip connector from radio shack. (just ask rep. to get you a 2 wire connector clip)
hope this helps...sounds harder than it seems..just trying to be descriptive..
Old Jul 18, 2010 | 04:58 PM
  #25
Kauaian's Avatar
haha...
...the hardware ring.
slide the new fog lights in the hardware ring you just removed from the old stock fogs(you will need a little muscle). line up the screw holes on the sides and use the provided screw and washer from the new fog light kit...tighten nice and snug.
Old Jul 18, 2010 | 05:45 PM
  #26
jay-nyc's Avatar
i change my fog to hids wich give a great light power but yea dude the 2010 fog light are shit even the housing with the clips are broken on both the hids lamp are been hold by zip ties
Old Jul 18, 2010 | 07:11 PM
  #27
Thank you sooooo much I really appreciate the detailed description because that's what I needed to understand how to do it. Would a dealer care if I hardwired the new lights? Also, if I did it the way you did and soldered the wires to a female/male clip connector from radio shack and ever needed to return my JK to stock, I could just repeat the process and re-cut the wires to re-solder them to a female/male clip connector again, correct?
Old Jul 19, 2010 | 12:37 AM
  #28
NH-JK's Avatar
ahhhh a new project to do!!!!! cant wait.
Old Jul 19, 2010 | 12:55 AM
  #29
Kauaian's Avatar
No prob!em!
This fourm has been very helpful to me, so I try to give back whenever possible
As for the dealer, they should have nothing to say about wiring in the new fog lights, or at least I would hope not
I just try to keep any and all mods I do myself on the Jeep nice and clean!
No duct tape, Mcgyver fixes please
As for wanting to go back to stock? Yes, just be sure to leave some extra wire on the stock connector before cutting it off and you can reverse and re-solder anytime...
Old Jul 19, 2010 | 12:59 AM
  #30
Kauaian's Avatar
Also...
If you read the entire thread..folks have done this WITHOUT removing the front bumper, and so did I...
ultimately its your choice, I saw no need to. less work for me
