Axle Breather Hose Extension Write-Up
http://project-jk.com/gallery2/main...._itemId=149196
In addition to installing things like longer sway bar links and brake line extension brackets, when you lift your Jeep JK Wrangler to a height of 3" or more, you will find that it’s a good idea to extend your rear axle breather hose as well. If you don’t, you may find that the hose will get pulled off the axle when flexing out on the trail. While this is not that big of a deal in and of itself, the hose being separated will allow water dirt and debris to get inside your axle and that can cause BIG problems. The write-up below will show you how to extend your axle breather hose in minutes and for dirt cheap. Axle Breather Hose Extension Write-Up :cool: |
Wow, such a simple solution. I will stop by the Pepboys on the way home tomorrow.
What lengths of fuel line do they typically sell, or is this an ordered item from somewhere like Summit? The diameter in the equipment section says 5/16", but the write up says 1/4"? |
Originally Posted by kflash
(Post 1381328)
Nice write up Eddie :thumbsup:...looks pretty simple and straight forward :yup:
Not to sound like a dumb girl but why does the axle have a breather? Why aren't they just sealed?
Thanks wayoflife for taking the time to post a write up for those who need it. |
Originally Posted by bluesurf09
(Post 1381590)
(Post 1381756)
LOL!! not a dumb question at all - girl or guy. as your axles, transmission or transfer case heats up, air and gases can build up and the breather allows them to escape.
The same steps and material would be used to lengthen the front axle and tranny vents correct??
Originally Posted by donnie
(Post 1384355)
OK Thanks.
