blacked the inside of my hardtop duplicolor truck bed liner
Thanks everyone for all the kind words. I love the look over the white. It did not cost a lot to do just very time consuming. It was a long proccess , it was mostly in the prep work. Good prep = good results. I agree the top should come like this from factory. Once this is cured this stuff seems to be unscratchable, so I am thinking next spring I will do the out side of the top with this stuff, It is way better then the paint that is on the top now. That paint can scratch off with my finger nail. Its like it was not prepped good from the factory that the paint will not stick. With this stuff you would brake your finger before you scratched it off. I can't really comment on road noise or insulation because I really never had my top on since I have had it. It came off the morning after it came home and has not been on since, but with the temps dropping it will be on by the end of the week. The top holder was home made, very easy to make and was under $40 to make.
...Once this is cured this stuff seems to be unscratchable, so I am thinking next spring I will do the out side of the top with this stuff, It is way better then the paint that is on the top now. That paint can scratch off with my finger nail.
I do like the top holder, I've got one drawn very similar to it.
Now for additional questions...
How well does it fit after the lining has been put on. Is there any misalignment from the hard top sitting on the Jeep? What about the twist knobs on the two smaller panels, does the extra thickness from the bedliner get in the way? Finally, when you were doing the prep work, did you remove the twist knobs, or leave them in... and did you put the liner in where the twist knobs go?
Thanks again for your input.
Thats just what I was going to ask about... the exterior. I can see I've scratched mine up just from sitting in the basement.
