A/C charge
I Have an 08 and the ac is just not as cool as it once was. I looked under the hood and it said that it held 1.25 lb now on the gage that came with the r134 It don't even start till 10 lb. what's a guy to do? Any pointers
Do you have a leak? A/c units don't use up Refigerant, If it is ever low then you have a leak.....There's a couple write ups here that show you have to use a Resistor to change the temp sensor etc under dash to have compressor run longer...good luck
